Power Consumption
For all of the performance tests, we disable all power-saving technology in order to give us a consistent set of results, and to give us best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the power consumption tests we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below represent the total system power draw from the mains, not the power consumption of the CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve.
We've also included the Raspberry Pi's claimed power draw of 3.5W for the Model B for comparison - this number is generally accepted although it should be taken as a general guide.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
        Raspberry Pi (claimed power consumption)
        Tranquil PC Abel H2-5
        Intel NUC DC53427RKE
        Intel NUC D33217CK
        AMD 5800K
        AMD 5600K
         Intel Core i3-4330 (3.5GHz)
        Intel Core i3-3220
        AMD A10-7850K (3.7GHz)
        Intel Core i5-3570K (discrete GPU)
    Watts, lower is better
Load Power Consumption
To generate a realistic load power consumption figure we need to load both the CPU and GPU portions of the processors. To do this we used prime95 to load the CPU and Unigene's Heaven benchmark to load the GPU.
        Intel NUC D33217CK
        Intel Core i3-3220
          50
          75
          100
          125
          150
          175
Thermals
As its unlikely you'll be gaming on the Abel H2-5, we used Prime95 to max-out the CPU to get an idea of how the case copes with demanding 2D tasks. We also placed the Abel H2-5 in a TV cabinet to see how well it fares in a typical usage scenario with little ventilation while streaming HD content from Netflix.
        Prime95 - case in TV cabinet
        Prime95 - case in the open
        Netflix HD movie stream - case in TV cabinet
        Netflix HD movie stream - case in the open
        Idle
    °C, lower is better
